stephenjfox
Feb 05, 2018Aspirant
Readynas 314 affects WiFi when connected to router
[ Spoiler ]
Feb 05, 2018Guru - Experienced User
What network settings are you using in the NAS? DHCP? Or have you tried to configure a static IP address?
Also, your title suggests the issue is with WiFi connections, but the body of your post says "internet connections". Which is it?
Can you get into the admin web ui of the NAS with the NAS connected to the router?
- stephenjfoxFeb 06, 2018Aspirant
Both internet and wifi drop out.
Had the ReadyNas Static on IPv4 and DHCP on IPv6.... Changed them both to DHCP but still same issue....
Yes, can connect to the NAS ui
- StephenBFeb 06, 2018Guru - Experienced User
Try disabling IPv6 in the NAS next.
What apps and services are you running (including any cloud apps)?
Ok..
Running Plex, MYsql, Python, myphpadmin
Dropbox sync as well
