stephenjfox
Feb 05, 2018Aspirant
Readynas 314 affects WiFi when connected to router
[ Spoiler ]
stephenjfox
Feb 06, 2018Aspirant
Both internet and wifi drop out.
Had the ReadyNas Static on IPv4 and DHCP on IPv6.... Changed them both to DHCP but still same issue....
Yes, can connect to the NAS ui
Feb 06, 2018Guru - Experienced User
Try disabling IPv6 in the NAS next.
What apps and services are you running (including any cloud apps)?
- stephenjfoxFeb 06, 2018Aspirant
Ok..
Running Plex, MYsql, Python, myphpadmin
Dropbox sync as well
- StephenBFeb 06, 2018Guru - Experienced User
What firmware are you running?
If disabling ipv6 doesn't resolve it, then try temporarily disabling dropbox.
- stephenjfoxFeb 07, 2018Aspirant
Latest firmwear updated the other day.. I know its not a firmwear issue as the problem has been ongoing for a while.
Ipv6 disabled and still problems... after a restart it is fine for about 30 mins then the dropouts start... completely disconnected and everything works fine. Will disconnect Dropbox and test
