IT-Dept
Sep 10, 2017Aspirant
Readynas 314 and Powerware 9130 UPS communication
Hello, I have a readynas 314 (Firmware 6.8.0) and have established a UPS connection to a Eaton 9130 UPS via internal network/snmp (under Power/UPS). There are no shutdowm parameters in the confi...
Marty_M
Sep 14, 2017NETGEAR Employee Retired
Hello IT-Dept,
It does appear that you are trying to connect UPS to your Readynas device. For a guide on on connecting UPS please go here and for additional information please visit this link.
Marty_M
NETGEAR Community Team
- IT-DeptSep 14, 2017Aspirant
Hi Marty,
Thanks for that but the original question is not answered. The issue is what settings can the NAS use to shut itself down. I can only assume when a low battery alert is sent from the UPS, the NAS shuts down. There are many alerts sent our on a Eaton UPS.
Thanks Phil
- StephenBSep 15, 2017Guru - Experienced User
Have you looked at the MIB you selected? I believe it reports
- upsmgBatteryRemainingTime: Remaining battery backup time.
- upsmgBatteryLevel: Battery charge level.
- upsmgBatteryVoltage: Voltage delivered by the battery.
I have no idea which of these signals triggers the NAS shutdown.
But I think the more important question is whether the NAS will actually shut down when the UPS battery drains. Since you aren't sure if the MIB you are using is actually the correct one, I think you need to test it.
I'd connect the NAS directly to the mains power, and put a test load on the UPS (any device you have handy that uses power - incandescent light, space heater, whatever). Then pull the mains plug on the UPS and let it drain. Then keep an eye on when the NAS shuts down.
