ufc3app
May 27, 2023Aspirant
ReadyNas 314 Firmware Download
I need to update firmware for readynas RN314 but I keep being directed on Netgears support site to a .img file which reports being corrupt. It will not mount It will not convert to iso How t...
- May 28, 2023
ufc3app wrote:
I'm trying to reset the admin password.Use the OS reinstall boot menu option. See pages 74-75 here:
That will
- reset the admin password to password
- reset the ethernet settings to use DHCP with no bonding
- disalbe volume quota (which can be turned back on from the volume settings wheel).
Sandshark
May 27, 2023Sensei
You don't mount it nor convert it to ISO, you install it in the NAS from the Systems/Settings page of the GUI.
ufc3app
I can't get to the system settings because I cannot log into it. I'm trying to reset the admin password.
- StephenBMay 28, 2023Guru - Experienced User
That will
- ufc3appMay 28, 2023AspirantGot it, that worked. Thanks!!
