ufc3app
May 27, 2023Aspirant
ReadyNas 314 Firmware Download
I need to update firmware for readynas RN314 but I keep being directed on Netgears support site to a .img file which reports being corrupt. It will not mount It will not convert to iso How t...
- May 28, 2023
ufc3app wrote:
I'm trying to reset the admin password.Use the OS reinstall boot menu option. See pages 74-75 here:
That will
- reset the admin password to password
- reset the ethernet settings to use DHCP with no bonding
- disalbe volume quota (which can be turned back on from the volume settings wheel).
ufc3app
I can't get to the system settings because I cannot log into it. I'm trying to reset the admin password.
May 28, 2023Guru - Experienced User
That will
- ufc3appMay 28, 2023AspirantGot it, that worked. Thanks!!
