flummoxed
Feb 03, 2016Aspirant
ReadyNAS 314 not copying data
Guys, PLEASE help me, I'm losing the plot! I spent a fortune a year or two ago on a ReadyNAS 314 which I got because I loved the previous ReadyNAS I had. I have an iMac on Yosemite which ...
Feb 03, 2016Guru - Experienced User
Can you clarify - are you saying TimeMachine isn't copying the data? Or is this a built-in backup job on the NAS?
flummoxed
Hi matey, TimeMachine works fine, it's just copying all the data now after I have reset the NAS but the backup jobs complete without doing diddly. It says the job is complete yet nothing is copied whatsoever. I just dont understand. Thanks Ross
- StephenBFeb 03, 2016Guru - Experienced User
Can you post the backup job settings here? Note you can post screen shots (there's an image icon in the toolbar).
- flummoxedFeb 03, 2016Aspirant
Hi,
Sure, these worked perfectly up until October then just stopped for no apparent reason....- StephenBFeb 03, 2016Guru - Experienced User
The place to look first is the remote source.
You might want to try the IP address of the mac, and not the name. You could also check that the mac is still set up to share the source folder. If you have another PC, you can attempt to see the Business folder from it.
