Piemaster
Oct 28, 2015Aspirant
ReadyNAS 314 running slowly after 6.4.0 upgrade
Since upgrading my 314 to 6.4.0 it's been running very slowly taking about 30 seconds to login to the admin page. Sometimes it doesn't even load it. Also AFP/TimeMachine connections are now very in...
Netrage2
Oct 30, 2015Aspirant
Same issues here.
I have additional problems as well that you may have and not have noticed.
The connection to the NAS drive drops out and my network can see the device but can no longer access it. If I force power down the device and turn back on it comes back to life for a few minutes and I can access the NAS, admin page and data but then it drops the connection again and I cant even access the admin page.
This is all because of the 6.4.0 update as it runs the backup every day and only started with these issues the day after the update.
I have my NAS set to power off at night and I am wondering if the NAS was still doing something to do with the update (which I did at 2pm) when the drive shutdown.
Losing all the data (7.1TB) on the NAS is not an option.
BennyKind
Oct 30, 2015Guide
Netrage2 I dont know if this will help you but we were having very similar problems.
I managed to get on the web interface for about 10 minutes without it dropping out. In those 10 minutes i managed to delete some of the snapshots and set the snapshot schedule to never.
This did not solve the problem completly but it did give me longer on the web interface to give me time to delete the remaining snapshots.
At first the 316 was still unusable but the next morning it was accessible, it wasnt sluggish and I have been using it as normal again for the last 5 days.
So basically try and delete any snapshots you have on there and remove any snapshot schedule. Although it means that you wont have any snapshots, it does mean that you can at least use your NAS until Netgear release some sort of fix for this.
I hope that helps you.
- Netrage2Oct 30, 2015Aspirant
Thats interesting as my first login time was around 10 minutes as well. I used the time to pull some important files off the drive and delete around 1TB of data that I dont need but then it dropped out.
How are you removing the snaphots, I have never removed them before and given I only have a few minutes to do it I would welcome your technique.
- BennyKindOct 30, 2015Guide
Im not very technical im afraid but you just need to go to 'Shares' > 'Timeline'
Then just click on the little grey arrows on the time line to delete. It is quite a painful process but it seems to have worked for me. If you do a search for deleting snapshots, there will be a more detialed method than what I have just described. I did have to do it in a couple of attempts but finally managed to get rid of them all.
Also make sure you set the snapshot schedule to never otherwise it will keep adding snapshots.
