Piemaster
Oct 28, 2015Aspirant
ReadyNAS 314 running slowly after 6.4.0 upgrade
Since upgrading my 314 to 6.4.0 it's been running very slowly taking about 30 seconds to login to the admin page. Sometimes it doesn't even load it. Also AFP/TimeMachine connections are now very in...
Piemaster
Oct 31, 2015Aspirant
Just an update to this. Following advice here and on other posts I've disabled all snapshots and deleted the ones that were already there. The 314 has been stable since (15 hours ish) and is responsive again.
This thread has a useful script you can run over ssh to delete existing snapshots a lot quicker than doing it through the GUI https://community.netgear.com/t5/Using-your-ReadyNAS/rn104-updated-to-6-4-0-and-possible-solution-to-random-lock-ups/td-p/993214
Hopefully Netgear will release a firmware upgrade quickly so I can turn snapshots back on.
- StephenBOct 31, 2015Guru - Experienced User
6.4.1 beta.
- Netrage2Oct 31, 2015Aspirant
Update:
Overnight the NAS seemed to complete the reprocess of the snapshots and the NAS let me access it fully this morning. I have since removed all existing snapshots and stopped any new ones from being created.
Looking at the logs, the event that keeps repeating for the time period that the NAS was unusable is related to reprocessing of the snapshots so it looks like any other request to the NAS be it for data access, admin access or even for it to reboot was ignored due to the overloaded work that the firware update had started. Now that work is finished the NAS seems to be usable again.
The only advice I can give to others with the same issue is to try and remove any existing snapshots, stop new ones being created and leave the NAS on 24/7 until it becomes stable.
At least we have a temporary fix unitl someone is brave(or stupid) enough to try the beta.
Not sure if I am brave or stupid (or both) but I did try a pre-release version on my RN102. I have had no problems with it (and I was seeing lockups during rsync backups before I installed it).
