aleksey256
Sep 19, 2017Aspirant
ReadyNAS 314 stuck at booting 99%
Hi guys, Around a week ago my NAS stuck booting at 99%. After a couple of hard reset attempts it booted successfuly. However, yesterday it got stuck again so I cannot boot it any more. When I powe...
- Sep 27, 2017
Thanks for sharing. I'm glad that your problem was resolved by the higher tier of NETGEAR Support. :)
Hopefully, other community members that are familiar with monitoring the Amazon and Plex services via SSH would comment on this forum thread and post helpful tips.
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
Sep 20, 2017Guru - Experienced User
If you are the original purchaser, and purchased between 1 June 2014 and 31 May 2016, then you have courtesy lifetime chat support. I suggest using that channel (my.netgear.com) while you are waiting here.
Of course, normal paid support via my.netgear.com is also a good option in this case. Though they will charge, they'll sort it out with minimum risk to your data.
You can also try booting the NAS in read-only mode - pages 74-75 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
