DavidMicallef
Aug 31, 2016Aspirant
ReadyNAS 316 Expanding Volume
Hi, I had 3 4TB WD Red's installed in my 6-Bay NAS using X-RAID and the time has come for me to expand. I am adding 3 more of the same drives. I added my first drive and all is going well (alth...
- Aug 31, 2016
DavidMicallef wrote:
1. Can I still read from the drive whilst it is resyncing data (e.g. Use Plex - as the movies are on the NAS)?
Yes.
2. Can I still write to the drive whilst it is resyncing data?
Yes
3. This is a hypothetical - What would happen if the power were to go out mid resync? Would there be any data loss?
It should continue with no data loss. - not something I'd recommend though.
Aug 31, 2016Guru - Experienced User
Yes.
Yes
DavidMicallef
Thanks for the help. #3 was more if the power were to drop due to a grid outage (as its a possibility because the sync takes so long)
Cheers
- StephenBAug 31, 2016Guru - Experienced User
Understood, and I have seen some posts where power was disrupted.
Having a backup plan is of course always recommended. I also suggest getting a UPS for the NAS if you don't have one.
Are you thinking about dual-redundancy (16 TB volume size) or sticking with single (20 TB volume size).?
