john_h1
Mar 18, 2017Tutor
ReadyNas 316 Front Panel light wont go out 6.6.1
For some reason the lights on my Readynas 316 front panel no longer go out. I've tried a reboot but they still stay on. Everything else seems to be working ok from what I can tell. I'm running OS ...
pingjockey
Mar 19, 2017Tutor
I just started having the same issue yesterday as well on my 316 with the same firmware. Support had me go into boot mode and I still had issues so they are sending me a new unit (Personally I think it's a software issue).
mdgm-ntgr
Mar 19, 2017NETGEAR Employee Retired
This comes up from time to time and is not easily reproducible. You may find that with a reboot or firmware update that things bo back to normal or that the front panel remains lit even after that.
- pingjockeyMar 19, 2017Tutor
I figured as much as the support agent wasn't able to explain the issue. I checked the apt history logs to see if maybe a package was updated or something but I didn't find anything,
Ultimately support decided to RMA the unit because the panel wouldn't work in boot menu mode either. At this point the panel is however working and responding (albiet slowly) now.
