Zarcc
Feb 06, 2019Aspirant
ReadyNAS 3200 - Can't Delete Volume
Having a spot of problem. Repurposing an old ReadyNAS for transition storage for my DR. However, when deleting the LUN that was on the iSCSI it errored out (Didn't save the error). Checking the do...
- Feb 07, 2019
John,
Thanks for both the welcome and the reply.
I was doing the reset through the GUI but the reset just wouldn't take for some unknown reason. My passwords, my network, and, of course, the volume remained.
I ended-up corrupting the volume so it would disappear off the system entirely by swapping disks and rebooting the device. After that, I was able to get the factory reset to take hold and now have it up and running.
JohnCM_S
Feb 06, 2019NETGEAR Employee Retired
Hi Zarcc,
Welcome to the Community!
The volume should have been deleted already if you have done factory reset. How did you do the factory reset? Did you do it using the GUI or through the boot menu?
Zarcc
Feb 07, 2019Aspirant
John,
