Paladax
Feb 06, 2014Aspirant
Readynas 3200 disk space issue
Hi there, I have 2 of these units with both 12X 2tB disks in them. One unit it the primary unit that is where all my other site servers backup to. That then mirrors the data onto the 2nd offsite un...
Paladax
Feb 17, 2014Aspirant
I have noticed something further on this issue and wondered if it was a Netgear "quirk" or if perhaps I have a problem with my data.
When I look at the space size of a folder in my backups. My Monday- Friday folder size show me a different size to if I actually go inside the Mon-Fri folders and then do a directory size inside of there.
For instance. If I am in a backup folder for a server and do a du * -sh it shows the following
Mon = 436GB
Tue = 73GB
Wed = 71GB
Thur = 80GB
Fri = 436GB
However, if I then go into the Wednesday folder and do the same du command it then shows me a total size of 436GB.
Is this right??
Mon = 436GB
Tue = 73GB
Wed = 71GB
Thur = 80GB
Fri = 436GB
Is this right??
