buriedpast's avatar
Sep 11, 2017
ReadyNAS 3200 RN12P Firmware / BIOS Reinstallation
Hello All - Just trying to get some confirmation or comments on the approach I intend to use on an upcoming project.   I recently aquired (hasn't even shown up yet) a ReadyNAS 3200 with 12 2TB driv...
  • buriedpast's avatar
    buriedpast
    Sep 21, 2017
    This unit is running great now thanks to the assistance received from mdgm.  Being who I am, I installed a disk and rebooted and the unit went into 6.8.0 with no problem.  Then I just had to perform a factory reset from RAIDar after which I then performed an OS update using the 6.8.0 img file just to make sure "all the electrons were properly aligned".  I'm very pleased.
    Just to clarify if anyone chooses this thread as a guide for their effort - nothing I proposed to do in my initial post or tried on my end contributed to this success other than the choosing of a good quality USB drive ... and it's a pretty helpless feeling.  It was only through some one-on-one TLC from the moderator that this unit is now functioning.  Kudos to them for all they do for us ... theirs is a selfless effort!
ProSupport for Business
