djkaejae
Aug 02, 2019Aspirant
ReadyNAS 3200 Updated Firmware 4.X to 6.9.5
I have updated my firmware in ReadyNAS 3200 Rack mount from 4.x to 6.9.5. I no longer can login management console. Admin/Password does not work. I tried booting recovery usb but the NAS will not rec...
djkaejae
Aug 05, 2019Aspirant
I have a monitor and keyboard attached. When the NAS boots it always stops at no device detected and no compatible platform message. I opened the NAS and got the flash drive connected to the motherboard. I am going to try and re-image the flash drive for Version 6.9.5. I think the flash drives I have been using are too new. (16gb). I am trying to get 6.9.5 to flash. I will try and load the r4tor6_6.9.5.bin on the flash drive.(what I used to update)
Sandshark
Aug 05, 2019Sensei
No, you can't load the update files directly to the internal USB. I hope you make an image before you try or you see this and don't try, or you could make your situation far worse. Those messages are normal, and then it should continue on. You should see it identify the motherboard and BIOS version (verifying it's a genuine Netgear system, not generic SuperMicro), a long pause, then finally a login prompt. I wish it gave more status during the boot like the virtual machine version does.
One thing that can make is stop booting if if it doesn't ID the system as genuine Netgear. You didn't try a BIOS update, did you?
When you remove the internal USB, get a listing of the files on it and post here. And make an image just in case anything you try does make it worse. Maybe you are missing something or have a mismatch of files and I can help identify them.
- djkaejaeAug 05, 2019AspirantOkay. I am glad I got this reply before I tried to load 6.x. So with the original image I get it to boot to the login screen. I have tried several combinations and failed. It tries to load with admin/password but flashes and prompts again. It shows firmware version 6.9.5. We detected that it’s getting a dhcp address but unable to connect using the web gui. Https://Xxx.xx.xx.x/admin. I will post the files currently on the internal flash tomorrow. We ran Raidar software on desktop and it sees the NAS with good disc but says Management Console Down. We have another NAS 3200 running 6.9.5 without issues. We thought maybe it has different motherboard.
- SandsharkAug 05, 2019Sensei
There is only one version of the 3200 motherboard.
Unfortunately, you can't log in via the console until you turn on SSH access. It sounds like you are very close. Did you do a full factory default after loading 6.x? Maybe you should try it again. Or use another tool to zero the drive(s) if you can't get to the boot menu.
If that doesn't work, this is what I would do: Make both an image and file copies of the content of the internal flash. Do the same with the flash from your successfully converted 3200. Then image the flash from the non-working one with the working one. See if that fixes it. Win32DiskImager or Passmark ImageUSB are good imaging tools for this.
I expect that will boot the system, at least if you have blank drive(s) installed. At that point, though, you will likely see that both units have the same serial number. Putting the orignal VPD file for that unit back on the flash should fix that. Some ReadyNAS get the serial number and model info from VPD and others from the motherboard DMI data. If your NAS has the right serial number without replacing VPD, you needn't bother. My 4200V2s need the VPD and my RD5200 does not. I have a 3200 motherboard, but it's not in a system.
- djkaejaeAug 05, 2019AspirantI attempted to do OS reinstall and Factory Reset from boot menu but it would always have same results as normal boot. Just goes to the login page. We rather not mess with the internal storage on working NAS but I hear what your saying. Do you think some of the files on the internal storage got corrupt during the update to 6x? We needed to update from 4x because of SMB3.
