jeremyotten
Mar 22, 2011Aspirant
Readynas 4200 losing iSCSI connection for 5 secs (15072737)
Hello,
we have 2x vmware ESXi 4.1 u1 servers with 4 GB paths each to the iSCSI SAN (ReadyNAS 4200).
We now have the problem that we sometimes loose the connection and the entire vmware environment hangs for 5 seconds. We let vmware analyse the logs and they have come up with this:
Please assist in fixing this!
We are on 4.2.15-SP1
Hello Jeremy,
vm-support logs show that ESXi host lost access to NetGear ReadyNAS4200 iSCSI array :
messages.2:Mar 21 14:39:26 vmkernel: 4:19:08:18.685 cpu11:4844)WARNING: iscsi_vmk: iscsivmk_StopConnection: vmhba37:CH:1 T:0 CN:0: iSCSI connection is being marked "OFFLINE" (Event:6) messages.2:Mar 21 14:39:26 vmkernel: 4:19:08:18.685 cpu11:4844)WARNING: iscsi_vmk: iscsivmk_StopConnection: Sess [ISID: 00023d000003 TARGET: iqn.2010-12.BIGFOOT:vmware.lun0 TPGT: 1 TSIH: 0] messages.2:Mar 21 14:39:26 vmkernel: 4:19:08:18.685 cpu11:4844)WARNING: iscsi_vmk: iscsivmk_StopConnection: Conn [CID: 0 L: 192.168.0.52:51125 R: 192.168.0.3:3260]
messages.1:Mar 21 14:39:28 vmkernel: 4:19:08:20.654 cpu7:4103)NMP: nmp_CompleteCommandForPath: Command 0x28 (0x41027f1ca540) to NMP device "naa.60014052e10897000c6d002000000000" failed on physical path "vmhba37:C1:T0:L1" H:0x2 D:0x0 P:0x0 Possible sense data: 0 messages.1:Mar 21 14:39:28 vmkernel: 4:19:08:20.654 cpu7:4103)ScsiDeviceIO: 1672: Command 0x28 to device "naa.60014052e10897000c6d002000000000" failed H:0x2 D:0x0 P:0x0 Possible sense data: 0x0 0x0 0x0.
messages.1:Mar 21 14:39:28 vmkernel: 4:19:08:20.676 cpu1:4097)NMP: nmp_CompleteCommandForPath: Command 0x12 (0x41027f9cc840) to NMP device "naa.60014052e10897000c6d003000000000" failed on physical path "vmhba37:C1:T0:L2" H:0x2 D:0x0 P:0x0 Possible sense data: 0 messages.1:Mar 21 14:39:28 vmkernel: 4:19:08:20.676 cpu1:4097)ScsiDeviceIO: 1672: Command 0x12 to device "naa.60014052e10897000c6d003000000000" failed H:0x2 D:0x0 P:0x0 Possible sense data: 0x5 0x24 0x0.
messages.1:Mar 21 14:39:31 vmkernel: 4:19:08:22.974 cpu2:4844)WARNING: iscsi_vmk: iscsivmk_StartConnection: vmhba37:CH:1 T:0 CN:0: iSCSI connection is being m arked "ONLINE"
On the other hand logs also show that iSCSI LUNs are using MRU as path policy and the Storage Array is detected as VMW_SATP_ALUA.
This is something that nees to be validated with your SAN Vendor as our HCL states that storage array type should be VMW_SATP_DEFAULT_AA and Path Policy should be VMW_PSP_FIXED.
Please engage your SAN Vendor to have this validated by them.
- yoh-dahGuideCan you send the logs (see my sig)?
- jeremyottenAspirantlogs send
- matelukasAspirantTaken by support. Case created.
- beisser1Tutori added the casenumber to the topic for reference.
- jeremyottenAspirantAfter updating to 4.2.16 and disabling CHAP and setting JUST ACL on iSCSI I haven''t had a single disconnect anymore.
Also when enabling the "VMWare round Robin" Path policy over my 4x 1GB MPIO Paths I get really really good performance. - Given that we're both having problems with CHAP, what's the NetGear-recommended way to restrict access to specific shares to specific machines? Should we be using initiator IDs?
- jeremyottenAspirantYes just ACL with initiator ID's
- gradgrindAspirantDid anyone ever get an answer to this?
I've got RN4200, connected now to the same 2960 switch as a single ESX 4i server. Server has 2 connections, jumbo frames not enabled, using a segregated VLAN to one of the RN NICs.
Keep getting the lost connection message. - jeremyottenAspirantOnly solutions is disable CHAP authentication on iSCSI on the Readynas 4200. Just use the ACL list with Initiator ID's the secure the connection.
- gradgrindAspirantAlready on that...
Any idea on the best load balance strategy for paths? The options are:
Fixed
MRU
Round Robin
VMW-PSP-FIXED_AP
I've tried RR and VMW-PSP-FIXED-AP, but getting the same on both.
