guitman
Dec 03, 2013Aspirant
ReadyNAS 4220 as ESXi Datastore - NFS way slower than iSCSI
I just set up a 12 drive 4220 and began some performance testing. Just simple file read and write operations. The 4220 is connected as a datastore to an ESXi host. I tried both as iSCSI and NFS. I...
mmcalister44
Mar 02, 2014Aspirant
I have a ReadyNAS 3220 running Firmware 6.1.6
My NFS is running very very slow.
According to VMware I have an Avg NFS Write Latency of 130ms!
What is very odd is I have two identical ReadyNAS 3200 units using NFS on the same network with a Write Latency of 1.4ms!
Did you ever get an answer? I read the release notes of 6.1.6 firmware and it mentioned it improved the NFS speed.
Any help would be appreciated.
M
M
