Blancatel
Mar 14, 2022Aspirant
ReadyNAS 424 - problem with audit logs - firmware 6.10.7
Hello team; I have problem with auditing logs, I always get this message 48009010000. I have updated the firmware, I have restarted, I have deactivated and activated again Audit Log. I can't ...
Mar 29, 2022Guru - Experienced User
This is a user-to-user forum, not paid netgear support. I suspect none of the other users felt they could help you.
I am tagging the two Netgear mods ( Marc_V and JeraldM ) to call their attention to your post.
Blancatel
Mar 29, 2022Aspirant
Hi StephenB
First of all, thanks for answering.
There is no way to delete the old audit logs, because I think that is the problem.
I can't clear the current audit logs, to start with no errors.
Any help possible is appreciated.
Greetings.
- StephenBMar 29, 2022Guru - Experienced User
Have you tried clearing all the logs from the log page?
You could also enable ssh, and try deleting them that way.
- BlancatelMar 29, 2022Aspirant
Hi again;
Yes, I tried to delete the logs from the logs page, although none appear, only Error 48009010000 continuously when entering Audit Log.
I was able to delete the old audit logs by FTP, but the problem persists: Error 48009010000. I didn't need to enable SSH.
I do not know what else to do, I need help.
