spwb
Jul 26, 2023Aspirant
ReadyNAS 424 unresponsive after 30 mins uptime
My ReadyNAS 424 often goes unresponsive after 30 minutes up time - the front panel buttons only light up blue upon pressing and do not bring up front panel info, and I cannot log into the admin page ...
Jul 26, 2023Guru - Experienced User
Have you downloaded the log zip file?
RAIDar also has a diagnostic you might try.
- SandsharkJul 26, 2023Sensei
Another option is to open an SSH window and run top in it, then see if a process is at 100% CPU at the time it crashes.
- spwbJul 28, 2023Aspirant
thanks for the "top tip" ha!
I have top running and will keep it open - if/when the system crashes again, I presume top will display the last refresh.
So far the tracker-miner-f command has been using 90%+ CPU for the past 25 minutes (the entire time the readynas has been up)
I'll report any further findings here.
Hi - thank you for the tips.
Re: the logs - Yes, I've downloaded the log .zip file - should I upload the entire archive here? I'm not sure if it would contain sensitive information - it contains 77 files - which could be relevant?
Re: RAIDar - i've run the diagnostics and it comes back with the following:
Successfully completed diagnostics
System
- Disk 1 has 16 Reallocated Sectors
- Disk 1 has 16 Reallocation Events
- Disk 1 has 408 Current Pending Sectors
- Disk 1 has 408 Uncorrectable Sectors
Logs
- No errors found.
