spwb
Jul 26, 2023Aspirant
ReadyNAS 424 unresponsive after 30 mins uptime
My ReadyNAS 424 often goes unresponsive after 30 minutes up time - the front panel buttons only light up blue upon pressing and do not bring up front panel info, and I cannot log into the admin page ...
Jul 26, 2023Guru - Experienced User
Have you downloaded the log zip file?
RAIDar also has a diagnostic you might try.
Sandshark
Jul 26, 2023Sensei
Another option is to open an SSH window and run top in it, then see if a process is at 100% CPU at the time it crashes.
- spwbJul 28, 2023Aspirant
thanks for the "top tip" ha!
I have top running and will keep it open - if/when the system crashes again, I presume top will display the last refresh.
So far the tracker-miner-f command has been using 90%+ CPU for the past 25 minutes (the entire time the readynas has been up)
I'll report any further findings here.
