ooCHUMoo
Jan 17, 2021Aspirant
ReadyNAS 424 XRAID Not Expanding
I was running 4x10TB (XRAID/RAID 5). I replaced two disk with 14TB so that the configuration is 2x10TB and 2x14TB. Resync completed, but volume size is the same as before installing the larger disk...
ooCHUMoo
Jan 18, 2021Aspirant
Yes, green stripe under XRAID so it's on. Furthermore, if I click on it, it asks if I want to turn off XRAID and switch to FLEXRAID.
If it matters, the drive/slot configuration is 14/10/14/10. I replaced the 3rd drive initially, and then the 1st drive.
Here's partitions.log:
major minor #blocks name
8 0 9766436864 sda
8 1 4194304 sda1
8 2 524288 sda2
8 3 9761718216 sda3
8 16 13672382464 sdb
8 17 4194304 sdb1
8 18 524288 sdb2
8 19 9761718216 sdb3
8 32 9766436864 sdc
8 33 4194304 sdc1
8 34 524288 sdc2
8 35 9761718216 sdc3
8 96 4883770583 sdg
8 97 131072 sdg1
8 98 4883638272 sdg2
9 0 4190208 md0
9 127 29284761408 md127
251 0 29284759360 dm-0
8 64 13672382464 sde
8 65 4194304 sde1
8 66 524288 sde2
8 67 9761718216 sde3
9 1 1044480 md1
Sandshark
Jan 18, 2021Sensei
If you are comfortable with SSH, the following command should start the expansion: volume_util -e xraid. If it doesn't, maybe it will at least give an error message that's helpful.
There are some more specific commands to tell it what drives to use, but I'm afraid that would mess up XRAID knowing the configuration. I've only used them in a FlexRAID unit, and then only for experimentation.
- ooCHUMooJan 18, 2021Aspirant
Interesting. Tried ssh and got an error:
admin@Galactus:~$ volume_util -e xraid
Expanding pools...
sh: 1: btrfs: not found
admin@Galactus:~$- SandsharkJan 18, 2021Sensei
Not especially helpful to me, but seems to indicate that some information on the XRAID configuration that it needs to determine how to expand is missing. Maybe one of the Netgear folks can better interpret it.
The logs indicate that MDADM and the rest of the Linux core are aware of everything, so it must be XRAID that's not, and I don't know where that's located. See if volume_util -s pool will provide more information.
Is the external; drive still disconnected? Maybe it's getting stuck looking for how to expand it, which it can't do, and never moves to the main volume.
The help on volume_util includes:
Usage: volume_util [-c NAME] [-c NAME D1,..,DN] [-c NAME LEVEL D1,..,DN]
[-c NAME LEVEL D1,..,DN KEY_FILE] [-d NAME|UUID]
[-x NAME|UUID] [-e] [-e TYPE] [-v NAME LEVEL D1,...,DN]
[-f NAME DISK] [-S DISK] [-F DISK] [-s TYPE..]
-e Expand pool TYPE is one of 'auto', 'expand', 'extend', or 'xraid' auto - automatically do all forms of expansion expand - expand to fill all space on all current disks (disk replacement) extend - extend pool to use available new disks (disk addition) xraid - grow pool to use available space on some current disks (partial disk replacement)There is a different command for Flex-RAID expansion and one for "Vdev expand pool", whatever that means, since the only references to Vdev I Google are for ZFS. Then again, ReadyDataOS used ZFS, I believe, so maybe that's just a leftover in the help. It appears clear that OS6 borrowed a lot from ReadyDataOS.
I think playing around with the flex-raid command option is a bad idea at this point, but maybe try volume_util -e expand, though I rather expect a similar error since that's what the xraid expansion type should have determined was needed, if I'm interpreting the command properly. You could try -e auto, too, likely with the same result. It doesn't say what -e by itself does, and it is allowed, so you could try that as well. My guess is it's just shorthand for -e auto and will also give the same result.
The Flex-RAID (-f) option lets you specify devices and the pool (volume), which is what that error message looks like it says it can't find, but I'm afraid it could make things worse if you are not in Flex-RAID mode. Of course, it might work and just not make it better for future expansion. If you want to try it, make sure you have a full backup in case a factory default becomes the only way out of a hole you dug yourself. volume_util --help will give you the options.
Switching XRAID off and back on has been known to fix issues for some, but it is possible that you will be stuck not being able to go back to XRAID, or possibly worse. So, again, be sure you have a backup before you try that.
volume_util -e expand (and auto) gave the same error as before:
admin@Galactus:~$ volume_util -e expand
Expanding pools...
admin@Galactus:~$Here's pool info:
admin@Galactus:~$ volume_util -s pool
Pools
Pool root:
Device: /dev/md0
Node: 9:0
HostID: 0a440448 (native)
UUID: b1ed4dd4-2e64-464f-b4f6-f670db7c1024
Mount point: /
Size: 3793952KB (3 GB)
Available: 3118324KB (2 GB)
RAID Level: 1
State: redundant
Action: idle
Flags: 0x68
Type: btrfs
Tier Flag: Disable
RAIDs:
md0
Level: 1
Action: idle
Members: 4
Type: 3
Flags: 0x28
Tier: 0
Data allocation: 0 GB
Metadata allocation: 0 MB
Unallocated: 0 GB
Disks:
sdd:
HostID: 0a440448
Flags: 0x1
Size: 27344764928 (13039 GB)
Free: 7811891214
Controller 0
Channel: 0
Model: WDC_WD141KFGX-68FH9N0
Serial: X0GZ1HMC
Firmware: 83.00A83
Class: SATA (3)
RPM: 7200
sdc:
HostID: 0a440448
Flags: 0x1
Size: 19532873728 (9314 GB)
Free: 14
Controller 0
Channel: 1
Model: ST10000VN0004-2GS11L
Serial: ZJV0MECF
Firmware: SC60
Class: SATA (3)
RPM: 7200
sdb:
HostID: 0a440448
Flags: 0x1
Free: 7811891214
Controller 0
Channel: 2
Serial: X0GYH9WC
Firmware: 83.00A83
Class: SATA (3)
RPM: 7200
sda:
HostID: 0a440448
Flags: 0x1
Free: 14
Controller 0
Channel: 3
Model: ST10000VN0004-1ZD101
Serial: ZA2A4XQC
Firmware: SC60
Class: SATA (3)
RPM: 7200
Pool swap:
Device: /dev/md1
Node: 9:1
UUID: cb058d6c-8287-44b6-9a98-9799db9df490
Mount point: none
Size: 0KB (0 GB)
Available: 0KB (0 GB)
RAID Level: 10
State: redundant
Action: idle
Flags: 0x28
Type: swap
Tier Flag: Disable
RAIDs:
md1
Level: 10
Action: idle
Members: 4
Type: 3
Flags: 0x28
Tier: 0
Disks:
sdd:
HostID: 0a440448
Flags: 0x1
Free: 7811891214
Controller 0
Channel: 0
Serial: X0GZ1HMC
Firmware: 83.00A83
Class: SATA (3)
RPM: 7200
sdc:
HostID: 0a440448
Flags: 0x1
Free: 14
Controller 0
Channel: 1
Serial: ZJV0MECF
Firmware: SC60
Class: SATA (3)
RPM: 7200
sdb:
HostID: 0a440448
Flags: 0x1
Free: 7811891214
Controller 0
Channel: 2
Serial: X0GYH9WC
Firmware: 83.00A83
Class: SATA (3)
RPM: 7200
sda:
HostID: 0a440448
Flags: 0x1
Free: 14
Controller 0
Channel: 3
Serial: ZA2A4XQC
Firmware: SC60
Class: SATA (3)
RPM: 7200
Pool data
Device: /dev/mapper/Data-0
Node: 251:0
UUID: 3f6282ad-bf0a-45f2-8e1b-8f3c4a49dae7
Mount point: /Data
Size: 29281453696KB (27924 GB)
Available: 7860386656KB (7496 GB)
Snapshot: 0KB (0 MB)
Data used: 0 MB (0 GB)
Metadata used: 0 MB
Unallocated: 0 GB
RAID Level: 5
State: redundant
Action: idle
Flags: 0x49
Type: btrfs
Tier Flag: Disable
RAIDs:
md127
Level: 5
Action: idle
Members: 4
Type: 3
Flags: 0x9
Tier: 0
Unallocated: 0 GB
Disks:
sdd:
HostID: 0a440448
Flags: 0x1
Free: 7811891214
Controller 0
Channel: 0
Serial: X0GZ1HMC
Firmware: 83.00A83
Class: SATA (3)
RPM: 7200
sdc:
HostID: 0a440448
Flags: 0x1
Free: 14
Controller 0
Channel: 1
Serial: ZJV0MECF
Firmware: SC60
Class: SATA (3)
RPM: 7200
sdb:
HostID: 0a440448
Flags: 0x1
Free: 7811891214
Controller 0
Channel: 2
Serial: X0GYH9WC
Firmware: 83.00A83
Class: SATA (3)
RPM: 7200
sda:
HostID: 0a440448
Flags: 0x1
Free: 14
Controller 0
Channel: 3
Serial: ZA2A4XQC
Firmware: SC60
Class: SATA (3)
RPM: 7200
admin@Galactus:~$
