RichWilson
Aug 31, 2019Tutor
ReadyNAS 426 - increasing capacity to existing full unit
I have the ReadyNAS 426 with 6 x 6TB drives configured with X-Raid Raid 5. I currently am at 79\80% capacity I have replaced one drive with a 10TB capacity. The unity resynced and the drives ar...
- Aug 31, 2019
When you are on XRAID mode and added 1st HDD of 10TB , There will be no additional capacity seen after Sync . Volume should be same around 27T even now . Space increase will be seen from the next drive added . Add the next 10TB , You should see a 3.6T increase in Space (Approx 30.5T) and the same will follow for the rest drives when repalced . This would happen only when the XRAID is on .
anna_arun
Aug 31, 2019NETGEAR Expert
