hellwiththis
Jun 09, 2022Aspirant
ReadyNAS 426 - problem with alert emails
ReadyNAS 426. Hello friends, I have suddenly developed a problem with email alerts. It's been working all along, but yesterday it stopped. No idea why; I haven't changed anything. I went to the ...
- Jun 10, 2022
hellwiththis wrote:
I must admit I'm a bit confused here....didn't we just establish that I can't use gmail? Unless I want to deal with their two-tiered security thing, which I really don't.
There are two parts to the alert setup
- who you want the alert emailed to
- what email account you want the alert mailed from.
You can set up the the alerts to be sent from Yahoo, and have them sent both to yahoo and to gmail.
Not sure if you can remove yahoo from the to list or not - it didn't matter to me, so I didn't try that.
hellwiththis wrote:
About that, what are you going to do?
I am still leaving 2FA off with gmail for now. I might change that later on (since I can trust the computer I normally use to read email).
But as far as alerts go, I've already shifted to sending from my yahoo account to my gmail address, and I think I'll just leave it that way.
Jun 09, 2022Guru - Experienced User
hellwiththis wrote:
ReadyNAS 426.
I went to the control panel and tried sending a test message and got this error:
Unable to send a test message.
Cannot send a test message. Check authentication settings.
Code: 500810001
Error from msmtp
Are you using gmail? I ran into this also. Google deprecated their "allow less secure apps" setting. I think you can still use app-specific passwords, but only if you have two-factor authentication enabled on the account. If you don't want to do that, you'll need to switch to a different email provider to send the alerts.
hellwiththis
Oh geez. There's the answer. StephenB you have solved my problems again! Thanks very much. I wonder if a yahoo account could do it?
Thanks very much brother, peace
- StephenBJun 09, 2022Guru - Experienced User
FWIW, I was thinking along the same lines. Yahoo does work (though it does require an app-specific password).
Though if you have a legacy NAS with only TLS 1.0 support ( 4.1.x firmware), then Yahoo's SMTP server will reject the email alert. Not a problem with the 426, just the sparc-based platforms like the NV+ v1 and Duo v1.
- hellwiththisJun 09, 2022Aspirant
I actually have a yahoo account but I just use it as a filter when I'm required to provide an email for some site and I know they'll be pestering me afterward. Using yahoo mail is annoying because it's got ads that you can't stop unless you give them money.
I've been looking at alternatives to gmail and I found this page:
https://themeisle.com/blog/gmail-alternatives/
Some of them look promising. If you have any thoughts, please do share them! And as always, thanks very much, StephenB.
True. But you can still send the alerts to your gmail address, so once set up you shouldn't actually need to log into yahoo very often. Just often enough to keep them from deactivating your mail.
I do have two 4.1.x NAS set up as secondary backups, and ideally would like to get alerts from them - and at the moment they require TLS 1.0. Looking at your list,
- Zoho says they won't accept TLS 1.0
- Microsoft says Outlook will accept unencrypted SMTP, but not TLS 1.0.
- The other four don't say, but it seems unlikely since they all focus on security.
So no good options here - and actually it is a bit surprising that gmail still accepts TLS 1.0.
