KenTanker0us1
Jul 26, 2018Tutor
ReadyNAS 426 safe shutdown HOW?
Hello friends. I'm back for more good advice from all of you wonderful experts.
Recently we had a power outage here and my whole network was on battery backup. We also lost internet connectivit...
- Jul 27, 2018
If you crack open the door, and press the power button twice, you should see a prompt on the LCD panel telling you to press it again to power down the NAS. If you do that, it should do a clean shutdown.
This does work on my RN52x ReadyNAS.
KenTanker0us1
Jul 31, 2018Tutor
Sandshark, thanks very much for your reply. I can't explain why, but I was definitely unable to use the control panel when I lost internet. Weird, isn't it. Could it be because I'm using Chrome? No idea. I won't worry as long as I have other ways of safe shut down.
I do have the NAS connected to a UPS, so it should work that way too. Question: I notice in the Power/UPS settings that it's set to Auto, and there are other choices for 10%, 20%, etc. I assume these percentages refer to battery life. Can you tell me at what percentage the Auto would do a safe shut down? I'm curious.
Thanks again for your time and help.
Sandshark
Jul 31, 2018Sensei
Auto is what I use as well. As the batteries get older, the time to go from a fixed percentage to zero goes down. So I don't want to be guessing.
