Supercows
Oct 29, 2021Guide
ReadyNAS 426 stuck on booting..
HI, after axpanding a disk the rebuild was hanging on 0,28%. Now my readynas wont boot in normal mode. If i boot in read only the log says that the firmware was upgraded. I cannot remind giving the...
Supercows
Oct 29, 2021Guide
Radair:
Successfully completed diagnostics
System
- Disk 2 has 52 Reallocated Sectors
- Disk 2 has 32 Reallocation Events
- Disk 2 has 3 Current Pending Sectors
- Volume data is inactive
- Volume data-0 is inactive
Logs
- 2021-10-29 20:10:35: md/raid:md127: raid level 5 active with 2 out of 3 devices, algorithm 2
- 2021-10-29 20:03:14: md/raid:md127: raid level 5 active with 2 out of 3 devices, algorithm 2
- 2021-10-29 19:59:03: md/raid:md126: raid level 5 active with 2 out of 3 devices, algorithm 2
- 2021-10-29 19:54:27: md/raid:md126: raid level 5 active with 2 out of 3 devices, algorithm 2
- 2021-10-29 19:46:44: md/raid:md127: raid level 5 active with 2 out of 3 devices, algorithm 2
- 2021-10-29 19:37:18: md/raid:md126: raid level 5 active with 2 out of 3 devices, algorithm 2
- 2021-10-29 19:27:00: md/raid:md127: raid level 5 active with 2 out of 3 devices, algorithm 2
- 2021-10-29 19:12:53: md/raid:md126: raid level 5 active with 2 out of 3 devices, algorithm 2
- 2021-10-29 19:09:24: md/raid:md127: raid level 5 active with 2 out of 3 devices, algorithm 2
- 2021-10-29 19:05:14: md/raid:md126: raid level 5 active with 2 out of 3 devices, algorithm 2
Oct 29, 2021Guru - Experienced User
Not sure what happened with the firmware update, but the log does suggest that the resync had finished before the reboot/firmware install.
Do you have 3 disks in the NAS?
Are you able to access the data in read-only mode? If so, I suggest backing it up (if you don't have an up-to-date backup already).
The errors on disk 2 are concerning. It would be useful to download the log zip file (which RAIDar should be able to do), and then copy/paste the contents of mdstat.log.
- SupercowsOct 29, 2021Guide
Thanks for your reply!
I have 3 disks in the readynas. I added 1 today.
Mdstat.log:
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md1 : active raid1 sdc2[2] sdb2[1] sda2[0]
523264 blocks super 1.2 [3/3] [UUU]
md126 : active (read-only) raid1 sda4[0] sdc4[1]
976619904 blocks super 1.2 [2/2] [UU]
resync=PENDING
md127 : active (read-only) raid5 sda3[3] sdb3[2]
2925416800 blocks super 1.2 level 5, 32k chunk, algorithm 2 [3/2] [UU_]
md0 : active raid1 sdc1[4] sda1[3] sdb1[2]
4190208 blocks super 1.2 [3/3] [UUU]
unused devices: <none>
/dev/md/0:
Version : 1.2
Creation Time : Wed Mar 16 08:41:11 2016
Raid Level : raid1
Array Size : 4190208 (4.00 GiB 4.29 GB)
Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
Raid Devices : 3
Total Devices : 3
Persistence : Superblock is persistentUpdate Time : Fri Oct 29 21:23:29 2021
State : clean
Active Devices : 3
Working Devices : 3
Failed Devices : 0
Spare Devices : 0Consistency Policy : unknown
Name : 0a4510d0:0 (local to host 0a4510d0)
UUID : 4858ca72:1e8ebe2a:dcbdda0a:4c08b023
Events : 1139Number Major Minor RaidDevice State
3 8 1 0 active sync /dev/sda1
2 8 17 1 active sync /dev/sdb1
4 8 33 2 active sync /dev/sdc1
/dev/md/data-0:
Version : 1.2
Raid Level : raid5
Array Size : 2925416800 (2789.89 GiB 2995.63 GB)
Used Dev Size : 2925416800 (2789.89 GiB 2995.63 GB)
Raid Devices : 3
Total Devices : 2
Persistence : Superblock is persistentUpdate Time : Fri Oct 29 20:03:16 2021
State : clean, degraded
Active Devices : 2
Working Devices : 2
Failed Devices : 0
Spare Devices : 0Layout : left-symmetric
Chunk Size : 32KConsistency Policy : unknown
Delta Devices : 1, (2->3)
Name : 0a4510d0:data-0 (local to host 0a4510d0)
UUID : 35e58e71:f4df1a57:38243e16:1e8a5376
Events : 122055Number Major Minor RaidDevice State
3 8 3 0 active sync /dev/sda3
2 8 19 1 active sync /dev/sdb3
- 0 0 2 removed
/dev/md/data-1:
Version : 1.2
Creation Time : Fri Oct 29 16:59:31 2021
Raid Level : raid1
Array Size : 976619904 (931.38 GiB 1000.06 GB)
Used Dev Size : 976619904 (931.38 GiB 1000.06 GB)
Raid Devices : 2
Total Devices : 2
Persistence : Superblock is persistentUpdate Time : Fri Oct 29 16:59:32 2021
State : clean, resyncing (PENDING)
Active Devices : 2
Working Devices : 2
Failed Devices : 0
Name : 0a4510d0:data-1 (local to host 0a4510d0)
UUID : 135af482:d759e7bd:2ad1f59b:8ea3bb81
Events : 1Number Major Minor RaidDevice State
0 8 4 0 active sync /dev/sda4
1 8 36 1 active sync /dev/sdc4unfortunately I cannot access data in readonly mode. Can I do something on ssh to make that possible?
Is there something I can do to fix this?
- StephenBOct 29, 2021Guru - Experienced User
The resync pending isn't something I've seen before.
It is possible to set the volume to read/write with mdadm
mdadm --readwrite /dev/md127
But I really don't know what will happen if you try that. It could make things worse.
What sizes are the disks? What disk did you add? Was it smaller than the others?
- SandsharkOct 29, 2021Sensei
There is no way the added drive did a RAID sync of the data volume in two minutes. The only things that could have completed sync in that time are the OS and swap partitions. I have seen that erroneous message at that time before (and, I think, I reported it here). It can make you erroneously believe that it is OK to go on with using the NAS as normal, but it's not. Consequently, it appears the system was re-booted and did an OS update while a sync was taking place, which can be bad. Resync pending is what you would see for md126 when md127 is still doing a sync. You have these two because you at one point had smaller drives, so you have two stacked RAIDs. But with something having gone wrong with the sync of md127 (because of the re-boot, I'm fairly certain), syncing has stopped on both.
You are seeing two volumes because BTRFS does not recognize that the two RAID layers go together. So, it has mounted one as data-0 (the name of the first MDADM RAID layer) and the other as data. But since neither is valid stand-alone, you have no access to the files.
While I recognize what you have, I've never seen them together, so also don't know your best next step beyond contacting Netgear support. It's possible that making md127 read/write will start it re-syncing. But then md126 will likely want to re-sync, and BTRFS may not recognize the file system properly until you re-boot after the both syncs complete. Or maybe re-booting without the new drive is the best move. md127 will come up as degraded, but maybe not read-only.
If you have no backup, so a factory reset is not an acceptable alternate if nothing works to fix it, you are best off leaving it to ReadyNAS support.
