greenlightcomp
Dec 20, 2021Aspirant
ReadyNAS 428 drive not adding to volume
Hi I have got a readynas 428 which I have been upgrading the drives from 3TB to 4TB and this was workin fine but when I have put in Drive 8 which is the last one it is not adding it to the volume whi...
- Dec 27, 2021
Hi Stephen,
Thanks for all your help on this, I have done the following which has fixed the issue,
Remove power from the NAS for 90 mins
Insert a brand new Ironwolf drive into Bay 8
Wait approx 24 hours for resync and new drive has been accepted and total capacity expanded.
Dec 23, 2021Guru - Experienced User
greenlightcomp wrote:
I am also expecting the total capacity should increase as all drives are now 4TB instead of having some 3TB ones in there, I am using flex RAID.
With X-RAID it would go up by 1 TB (from 27 to 28 TB). The resync would happen in two steps (because you would have two RAID groups, due to the original mix of 3 and 4 TB drives).
But FlexRAID is another matter. You have a 21 TB RAID-5 volume now. The KB article says it should expand to 28 TB, now that all disks are the same size. https://kb.netgear.com/23136/How-do-I-vertically-expand-a-Flex-RAID-volume-on-my-ReadyNAS-OS-6-storage-system
Let us know whether that happens. BTW, the expansion will start after the resync completes (and will look like a second resync from the web ui). You won't see the capacity increase until that second resync completes. That will take a while (though not as long as the first resync).
BTW, you really do need the space. BTRFS doesn't behave well when the file system gets very full (and yours is about 98% full). After the expansion completes, I recommend running a balance from the volume settings wheel. That might free up more space. It might take a while (days) if you've never run one before. Then perhaps set up a maintenance schedule (also done on the volume settings wheel). I run one of the 4 maintenance functions every month (cycling through the set 3x over the year).
greenlightcomp
Dec 27, 2021Aspirant
Hi Stephen,
