phistrom
Jun 28, 2017Star
ReadyNAS 4312X Initial Sync Incredibly Slow
To create a RAID10 array of 12x 6TB drives the web interface is giving me an estimate of 178 hours. After waiting a day it dropped to 154 hours so I guess it's pretty accurate. Is there anything ...
- Jul 03, 2017
I have created a RAID 10 array and it completed syncing within almost precisely 2 days (48 hours, 21 minutes, and 16 seconds).
The way I did it was by following the advice here. I am going to paraphrase it here in case that page ever goes down in the future.
- Create a RAID 10 array using the ReadyNAS GUI as usual.
- Stare, mouth agape, at how long that volume will take to finish its initial sync.
- Enable SSH under the settings tab so you can get shell access to your NAS.
- Log in with the user name "root" and the password whatever you gave to the "admin" user of your NAS.
- Set the "read ahead" of your array to 32 mebibytes with the following command:
blockdev --setra 65536 /dev/md127
(it's 65,536 times 512 bytes which comes out to 32 mebibytes) - Disable NCQ on all your drives. I'd recommend you make a script for this as follows:
#!/bin/bash
for drive in sd{a..l}
do
echo 1 > /sys/block/$drive/device/queue_depth
done
The part that says {a..l} assumes you have 12 drives. You're going to need to change the l to whatever the last disk letter you have is.
According to some sources, this doesn't actually disable NCQ. It would require a kernel parameter to do that but I have no idea how to set kernel parameters on ReadyNAS OS 6. The kernel parameter is:
libata.force=noncq
So maybe at some point the Netgear devs can implement it. The rationale is, apparently mdadm can do the queuing better than the hard drive can so you want to disable all the disks' NCQ.
One of the recommendations from that link (Tip #5) is to create a bitmap. I think that just makes resyncs or rebuilds faster but I don't believe it makes initial syncs faster so I would just ignore it.
Sandshark
Jul 03, 2017Sensei
WoW! Thanks for sharing. I wonder if that would have helped with my 10-day conversion of a 3TB x 6 RAID5 to a 3TB x 7 RAID6. Too late now, it's done.
phistrom
Jul 04, 2017Star
You're very welcome.
It's entirely possible that you could still see some performance benefits from making the changes I list above. Just be careful to write down what the current settings are in case the changes have a negative effect on performance. For instance, you can safely run
- blockdev --getra /dev/md127 to get what the current read-ahead value is for your array.
- cat /sys/block/sdX/device/queue_depth to get the current queue_depth for one of your drives (substitute X with a, b, c... etc)
If you take a look at the article linked in my previous post, Tip #3 mentions setting a "stripe-cache_size" for RAID 5 or RAID 6 arrays. I skipped this because I was talking specifically about a RAID 10 array here. Looks like you need to be careful with what you set that value to as it seems to increase performance by using more RAM and if you set the value wrong, you could run into Out of Memory conditions.
