wolfgangcc
Mar 09, 2018Aspirant
ReadyNAS 516 not showing Shares in Frontview (GUI)
I'm running Firmware 6.9.2 and ran into an issue months ago were i had to recover the NAS. Since the recovery I havent been able to see most of my shares in web interface. If I map the drive i get th...
Mar 09, 2018Guru - Experienced User
One thing you could try is
- rename one of the public share folders (subvolume)
- create a new share with the original name
- delete the new subvolume with btrfs subvolume delete -c \data\sharename
- rename the original public share folder to the original name.
If that restores the share to the Web UI, then you could repeat that for the rest of them.
mdgm-ntgr
Mar 09, 2018NETGEAR Employee Retired
That's one way of dealing with it.
Another way would be to try to fix the config files (there's a way that needs to be handled).
