WLS-ITGuy
Oct 31, 2025Aspirant
ReadyNAS 516 Stuck at booting
Hello all, I have searched the forums and tried the boot menu/OS ReInstall route and am now reaching out to see if there is another way to get my ReadyNAS 516 to boot. I have 22 years of family p...
WLS-ITGuy
Nov 02, 2025Aspirant
Powered down, removed disks and powered up and it is working. It is basically reset, default password, new IP address and says does not detect any disks.
- WLS-ITGuyNov 02, 2025Aspirant
I changed the password. Didn't set any new IP address. Put the drives back in and it stalls at booting...
The RAID was fine and working. No red lights on the NAS.
- StephenBNov 03, 2025Guru - Experienced User
All expected behavior if there are no disks.
What does RAIDar tell you (if anything)?
I am unclear as to whether you did an OS reinstall from the boot menu when the problem occurred or not.
BTW, do you have experience with the linux command line?
