DeeCee52
Dec 28, 2017Aspirant
readynas 524 stuck on btrfs delete delayed dir index
Readynas 524 x4 totaly locked up with the following display btrfs delete delayed dir index During incident 4 people were working on files from the nas, with programs that periodically write back o...
DeeCee52
i finally powered down and I repowered the unit, which is back online. I downloaded the logs.
It rebooted fine, but there is really no load on it at the moment.
Dec 29, 2017Guru - Experienced User
I'd check the SMART stats in disk_info.log.
- DeeCee52Dec 29, 2017Aspirant
I have looked at the logs as well as the info from the browser dashboard and the disks are fine. I have little experience reading logs, so that is about as far as I got.
- StephenBDec 30, 2017Guru - Experienced User
Hopefully a Netgear mod will want to analyze the log zip file for you.
If the NAS is running ok now, then I'd just keep a eye on it.
- DeeCee52Dec 30, 2017Aspirant
Worked fine for 30+ hours. syncing a Revit file brought up the same error. Nothing obvious on the disks or anything else that I can see. No errors showing in logs on the admin dash. Nothing that I can see in the log files I'm looking at.
