DeeCee52
Dec 28, 2017Aspirant
readynas 524 stuck on btrfs delete delayed dir index
Readynas 524 x4 totaly locked up with the following display btrfs delete delayed dir index During incident 4 people were working on files from the nas, with programs that periodically write back o...
DeeCee52
Dec 30, 2017Aspirant
Worked fine for 30+ hours. syncing a Revit file brought up the same error. Nothing obvious on the disks or anything else that I can see. No errors showing in logs on the admin dash. Nothing that I can see in the log files I'm looking at.
Dec 30, 2017Guru - Experienced User
If you have disk spindown enabled, try disabling it.
- DeeCee52Dec 30, 2017Aspirant
thank you for your responses. I don't believe I have checked disk spindown. although none of the shares were using quotas, I have unchecked that. I do have bit-rot checked.
The reply isn't allowing me to post the kernal log, but there is definitely something there. Way beyond my knowledge.
Definitely a file system problem. If this means a factory reset, I don't know whether to stay with the system. Never had this problem with the 314 or the Ultra Pro. Very disconcerting.
Not great that I'm 30 days beyond my support...
- mdgm-ntgrDec 30, 2017NETGEAR Employee Retired
Please send your logs zip in (see the Sending Logs link in my sig).
