SpaceTintin
Nov 29, 2021Star
ReadyNAS 6.10.4 and 6.10.5 rsync whole volume problem
Has anyone confirmed if the rsync issue has been resolved in 6.10.6? Referring to previous forum threads on the topic https://community.netgear.com/t5/ReadyNAS-Beta/OS-6-10-5-Beta/m-p/2087755 ...
- Nov 29, 2021
I haven't had a chance yet (my rsync backups are all "pull")
But if you use this feature, there is a setting you should try - "Multiple File Systems" on the Advanced tab of the backup job settings.
Someone from Netgear ( dingjs1421 ) said that checking that box would solve the problem back in September - but AFAICT no one using push backups of the entire data volume has actually tried it.
It'd be good if you did set it, and let us know if that solves the problem (or not).
Nov 29, 2021Guru - Experienced User
- SpaceTintinDec 02, 2021Star
I was able to test his tonight during off hours at the office. This appears to correct the problem! Thank you for finding and sharing this information. I am happy to able to upgrade to the current edition of ReadyNas OS. :)
- StephenBDec 03, 2021Guru - Experienced User
SpaceTintin wrote:
I was able to test this tonight during off hours at the office. This appears to correct the problem!
Great!
