superjuventino
Nov 18, 2017Tutor
ReadyNAS 6.9.0 (RN214) - Timeout when checking for updates
Hi, I checked the discussion boards for a similar problem and tried the suggested solution however I'm still having issues. I have full access to the ReadyNAS on my network as well as access ...
- Nov 19, 2017
Is NTP working (keeping the time in sync? ). You can toggle the NTP service using the settings wheel next to "device time" on the system overview page. uncheck the checkbox, apply, check the checkbox, apply.
When you apply the second time, the system should let you know if the NTP service succeeds (or not).
grindstr
Nov 19, 2017Guide
Hi, I have the same problem.
Running 6.9.1-T119. Also tried DNS 8.8.8.8, but to no help.
Any solution?
- StephenBNov 19, 2017Guru - Experienced User
- grindstrNov 19, 2017Guide
Hi StephenB
Thanks for your respond. I tried again right now, without doing anything about NTP. Ie, the clock is correct.
Check for Update is now working again. Could be that the software server was off-line for some time?
Anyway, thanks again for responding to this problem.
grindstr
- superjuventinoNov 19, 2017Tutor
NTP was working correctly. Update works for me now as well. Guess it must have been an issue on the server-side.
Thanks!
Sounds like it.
