mdshelton123
Mar 25, 2024Aspirant
ReadyNAS 6 Ultra RNDU6000 Stuck on "ReadyNAS"
Hi, I'm hoping not to have lost all my data. I haven't turned on my RNDU6000 in a while, the last time I did was to do an upgrade.. It is now stuck on the "ReadyNAS" display. After doing forum rese...
mdshelton123
Mar 26, 2024Aspirant
Hi Sandshark,
Thanks for your reply.
The power supply was tested under load, connected to the mainboard with a spare drive installed. All pinout voltages appeared within spec as per standard ATX pinouts.
Thanks for the tipabout the USB device, I will try some older ones.
Re.and VGA header, its been a long time since I was in the business of repairing PC's, but I have a friend who does this for needy people and he has a garage full of spares, I'm sure he will have a 6 pin IDC to VGA connector as they were used on a number of motherboards.
I'll see how I go, I'm thinking its the motherboard as there was a bit of insect waste on it.
Thanks, Mark
plague69
May 01, 2024Aspirant
I had the same issue and go it to the point where it boots and I see the front view but cannot do anything with it. Windows share can see and use the shared drive as normal though. (Since no frontview, cannot set permissions for the folders)
Apparently OS6 doesn't need the VPD file anymore. If you can get into TTL through tech support mode you can try the R4toR6 upgrade. There are 2 files, 1 "prep" and 1 of the actual OS. The prep you'll have to do manually using TTL, the OS file can be flashed using the USB+hold backup button while powering up.
To manually apply the prep bin file, get 7zip and extract the contents. Run the command (I forgot what) from the init file.
Rename the R4toR6 file to the normal firmware filename for OS4 and use the USB recovery tool for OS4 to load it onto the NAS. After turning on and holding the backup button, count to 3 after you hear the fans spin down a little. After 2-5min max, it should turn itself off. If it hasn't then the USB didn't work
- SandsharkMay 02, 2024Sensei
Since updating to OS6 destroys the OS4.2 data, that's not a solution when someone is trying to recover their data..
- plague69May 02, 2024Aspirant
I think there will be more and more of these cases popping up. There should be an automated VPD signing service from Netgear now that mods no longer have time to do this. What a shame...
OP has the option to put all drives into a linux tower and run "R-Studio for Linux" to recover files. But if the VPD has exploded, then the ReadyNAS is another headed for the garbage pile. Unless you want to short/hold down the backup button and keep a USB in there the whole time
