Marq1
Aug 28, 2011Aspirant
ReadyNAS 600 TL drive changes
In case it matters at some point, here's the exact model: Model: ReadyNAS 600-TL Serial: xxxx Firmware: RAIDiator 4.1.7 [1.00a043] Memory: 1024 MB [2.0-3-3-7] My good old RN 600 is stil...
PapaBear1
Aug 28, 2011Apprentice
You may have to perform a factory default. This will of course wipe the data. But don't do it unless your are secure with all the data needed is on the Duo. A member more experienced with Flex-Raid may have a better idea. If you factory default, you may want to use X-Raid rather than Flex-Raid.
