GRS1
Aug 27, 2017Tutor
readynas 600 won't boot slow flashing blue light
I connected to the NAS both through the web interface to check the backup jobs. They seem to have been failing for several months with unknown error. I could see the files via CIFS. As I looked th...
GRS1
Jan 28, 2018Tutor
Misunderstanding. I'm sure its the right image. I'm just not sure that writing the image and trying again will help.
That was then, this is now. I seemed to remember one of the old CFs I had lying around had an image on it, but I didn't want to use the giant (at the time) 2GB CF, so I rewrote to the original.
Lo and behold, I tried the 2GB CF and I have a link light, and it shows up in RAIDar.
RAWrite on the original CF, and it shows a link light and shows up in RAIDar.
It isn't up and running yet, but there is a clear path forward.
As an aside, I looked a long time for the firmware and couldn't find it. Although it would be a little work, a sticky with a list of at least latest firmware and which models they apply to could be really useful.
Many thanks, moving along, lets see what happens.
GRS1
Jan 28, 2018Tutor
Initializing! Will check back in 2 or 3 days. :-)
- mdgm-ntgrJan 28, 2018NETGEAR Employee Retired
The Infrant ReadyNAS 600 was discontinued well before the NETGEAR acquisition, I think. So it hasn't been sold for well over 10 years.
The Sparc Release Notes mention the NETGEAR models that the firmware is for and the Infrant models. However most KBs are just for NETGEAR models.
