eph3
Mar 08, 2026Aspirant
ReadyNAS 628 expansion not starting
ReadyNAS 628x running firmware 6.10.8 in RAID6 NAS has operated flawlessly for many years with eight (8) 14TB drives. A recent drive failure led me upgrade to: Four (4) 14TB drives F...
- Mar 30, 2026
Some good if mysterious news! Since I was going to have to reformat the system to get more space, I completed upgrading from 14TB drives to 24TB drives. I added the 24TB drives (hot) one at a time letting the ReadyNAS return to redundant status after each drive was added. Adding each new drive took a couple days.
I added the eighth 24TB drive this weekend. Imagine my surprise this morning when I saw the message that it had resynced. FrontView reports that the data volume is now 130.94TB. Apparently, encrypted vertical expansion can occur but only when all drives have been upgraded to a larger size.
For what it's worth, my ReadyNAS 628 is on firmware 6.10.8.
Mar 09, 2026Guru - Experienced User
eph3 wrote:I should have mentioned the volume is encrypted
Encrypted volumes can't be vertically expanded, so you'll need to destroy the volume and start over in order to use all the space.
eph3
Mar 09, 2026Aspirant
Ouch! If I ever knew that, it is long forgotten.
If I recreate the encrypted volume, will the 4x14TB plus 4x24TB drives result in a (6x14TB) volume or a (4x14TB)+(2x24TB)volume?
- StephenBMar 09, 2026Guru - Experienced User
First, an unencrypted RAID-6 volume would have a volume size of 104 TB (~94.6 TiB). There would be two RAID groups - 8*14TB spanning all disks, and 4*10TB using the remaining space on the 24 TB drives. So capacity would be 6*14 + 2*10.
I am not sure what would happen if you encrypted the volume. You mght get the same 104 TB, but I am thinking it is more likely that you'd end up with 84 TB instead (same as you have now).
A more predictable path would be to set up two RAID-5 volumes - 4x14TB and 4x24TB. Those could each be encrypted, and the capacities would be 42 TB and 72 TB respectively (114 TB total).
- SandsharkMar 10, 2026Sensei
Or consider if you really need encryption at all. Since you need the USB key to boot, most users leave it in the unit or near by, pretty much defeating the usefulness of encryption if the unit is stolen since the thief will also get the key. If you are encrypting so data on a removed drive isn't recoverable, you can simply plan to erase the drive. If the drive has failed and can't be erased, consider whether you have any data on it that's so prized that somebody would go through the effort of trying and recover it from a single non-working drive from a RAID.
And one more thing: There is no recovery software available to recover an encrypted ReadyNAS volume. If your NAS dies, the only recovery is by buying a replacement or, perhaps, using a ReadyNAS virtual machine (I've done recovery on a VM, but never used encryption on the VM for anything).
