ambrosecruz
Apr 04, 2017Aspirant
ReadyNAS "Admin Page" is offline
HI All,
I have recently purchased ReadyNas 214 after i upgaraded the firmware to 6.6.1 i am unable to get the admin page.
Both the network interface our configured with the same IP.
- Apr 04, 2017
Please download the logs using RAIDar 6.2 and send them in (see the Sending Logs link in my sig).
chsu83
Apr 04, 2017Luminary
Did you really configured both network cards? With same settings?
Normally switches don't accept that.
Because with no load balancing / teaming feature no client would know on which interface it should connect.
Load Balancing / teaming and so on doesn't work only if you configure all interface the same way.
It must be configured the "correct" way switch and device are able to communicate against each other.
That would explain why it works, when you connect it directly to your machine (only one link connected).
