ambrosecruz
Apr 04, 2017Aspirant
ReadyNAS "Admin Page" is offline
HI All,
I have recently purchased ReadyNas 214 after i upgaraded the firmware to 6.6.1 i am unable to get the admin page.
Both the network interface our configured with the same IP.
- Apr 04, 2017
Please download the logs using RAIDar 6.2 and send them in (see the Sending Logs link in my sig).
ambrosecruz
Apr 05, 2017Aspirant
Hi Team,
Please let me know if anyone body has solution for this.
I am awaiting for the solution.
- StephenBApr 05, 2017Guru - Experienced User
Were you able to download the logs with RAIDar?
If not, does the NAS respond to ping?
- mdgm-ntgrApr 05, 2017NETGEAR Employee Retired
Boot to volume read-only mode (a boot menu option) and then go to https://ip.address.of.nas/fwbroker and update to 6.7.0. If you still have the problem try an OS Re-install. It should then disable quotas at the volume level.
This change'll stick till you change share settings.
You have a huge amount of metadata on your volume.
- ambrosecruzApr 05, 2017Aspirant
Can you please guide me from where to do this.
Because when i plug the power in its start i dont know how to boot the Firmware with read only.
I am able to download the logs and i have downloaded the logs.
Secondly Nas pings i am able to access the internal folder which are shared.
The problem is i am not able to open the admin page
