ambrosecruz
Apr 04, 2017Aspirant
ReadyNAS "Admin Page" is offline
HI All,
I have recently purchased ReadyNas 214 after i upgaraded the firmware to 6.6.1 i am unable to get the admin page.
Both the network interface our configured with the same IP.
- Apr 04, 2017
Please download the logs using RAIDar 6.2 and send them in (see the Sending Logs link in my sig).
Apr 05, 2017Guru - Experienced User
Were you able to download the logs with RAIDar?
If not, does the NAS respond to ping?
mdgm-ntgr
Apr 05, 2017NETGEAR Employee Retired
Boot to volume read-only mode (a boot menu option) and then go to https://ip.address.of.nas/fwbroker and update to 6.7.0. If you still have the problem try an OS Re-install. It should then disable quotas at the volume level.
This change'll stick till you change share settings.
You have a huge amount of metadata on your volume.
