mixquilz
Jul 05, 2017Aspirant
ReadyNAS "Admin Page" is offline
Hi There.... been using an RN102 for about 2 years now but only intermittently update the firmware. updated last time to i think 6.7.1 but when updating to 6.7.4 the connention to the NAS would be ve...
- Jul 06, 2017
mixquilz wrote:
Yep I can get the logs using that.... but just didn't know who to send to
Hang onto them for now, hopefully a mod will ask for them.
Does https://nas-ip-address/fwbroker respond?
If it does, you could try over-installing 6.7.5 (or even installing 6.8.0-T54 beta) that way. If might solve the admin page problem.
mixquilz
Jul 06, 2017Aspirant
Thanks... Fwbroker was responding earlier this afternoon so I'll try and install the beta tomorrow and check back! Thanks so much for this..... I think just someone replying calmed my nerves a bit!
- mixquilzJul 06, 2017Aspirant
god i love you.... installed the beta and admin page came back online!
looks like my second disk was causing errors but not really sure why. buying another drive to replace but just a quick question... if i take out the second drive and replace it with a new drive, will it automatically sync the second drive properly?
- StephenBJul 06, 2017Guru - Experienced User
Yes, as long as you are using XRAID or a FlexRAID mode with redundancy. The new drive needs to be at least as large as the old one.
You can hot-swap with the NAS running.
sweet.... perfect excuse to buy a larger drive!
will be quote this when the missus asks why i need to buy a bigger drive and i'll just say the "The new drive needs to be
at least aslarger then the old one"thanks again!
please note that i did try to overinstall first but didn't work so had to manually update to 6.8.0 beta
