PeterWgtnNZ
Jan 25, 2016Aspirant
ReadyNAS and El Capitan - Problems!
Hello, I am running El Capitan (OSX 10.11) on my Mac laptop. I have 3 shares on my ReadyNAS Duo V2, using the latest version of RAIDar (6.1) I can see the device (which is plugged into the ro...
- Jan 26, 2016
I just checked and I can connect to my Duo v2 via AFP without any issue. I am running 10.11.2 at the moment.
This sounds like a discovery issue. You might want to try globally turning off the AFP service then starting it again.In the Finder if you go to Go > Connect to Server, can you connect to afp://192.168.1.50 ?
BrianL2
Jan 25, 2016NETGEAR Employee Retired
Hi PeterWgtnNZ,
Welcome to the community!
Try to disable and enable the AFP protocol on those shares and once enabled, ensure Everyone is set to R/W and the Allow Anonymous Access checkbox is ticked. Resetting the permission of the said share is also a procedure you can try if the above suggestion didn't work.
Device Software Manual - check pages 33-35
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
mdgm-ntgr
Jan 26, 2016NETGEAR Employee Retired
- PeterWgtnNZJan 27, 2016Aspirant
Thanks I'll try this a.s.a.p. & report back.
Peter
