BillReamy
Nov 28, 2017Aspirant
ReadyNAS and Orbi interaction
Not sure if this problem is ReadyNAS related or Orbi related. One of my two RN214's is connected via ethernet to the Orbi satellite and is apparently having problems staying connected to other device...
BillReamy
Nov 29, 2017Aspirant
Marc_V
I installed the 6.9.1 firmware but I am still seeing the same problem. I have never caught the first message to appear on the unit's display but it continues with "Network Changed" followed by "No IP Address". That usually repeats once or twice and then the unit gets its original IP address. This of course interrupts the video playback (either a DVD or a Blu-Ray ISO file using Power DVD 16) and causes the program to stop running. I noticed that in one of the Orbi threads that the Orbi system could be causing the problem.
Bill Reamy
Marc_V
Nov 30, 2017NETGEAR Employee Retired
Hi BillReamy
Have you tried setting up a static IP for the NAS? Have you tried changing the cable connecting the NAS and the Orbi?
You can try changing the port where the NAS is connecting from the Orbi.
It would be better if you can contact NETGEAR Support for assistance on your Orbi and ReadyNAS if all steps will still not help resolve the issue
Regards
