dougo
Jul 22, 2011Aspirant
Readynas beta for Lion (AFP fix) hoses Mac
Hi, First, thanks for your quick work addressing the Readynas Lion problems. For some reason, it's not working for me. I've got an NV+. I installed the Readynas beta for Lion to get afp workin...
kraney
Jul 23, 2011Aspirant
I'm having the same problem - posted in viewtopic.php?f=17&t=55161&start=15
I found that I can connect fine as guest or another user. I only get the core dump when connecting as myself. This means time machine works fine since it uses the ReadyNAS ID. I get the difference from my account versus another even connecting to the same, brand new, empty share.
I thought it might have to do with auth info coming from the keychain, so I removed the saved password. No change.
