dougo
Jul 22, 2011Aspirant
Readynas beta for Lion (AFP fix) hoses Mac
Hi,
First, thanks for your quick work addressing the Readynas Lion problems. For some reason, it's not working for me.
I've got an NV+. I installed the Readynas beta for Lion to get afp working again.
The afpd on the NAS is segfaulting in a loop. Something is working just well enough in the process that the mount attempt never gives up on my mac. Since the mount is underway, the finder is mostly useless and I can't cancel the mount. I can't do much of anything. It took a couple of tries until I restarted the NAS and completely disabled AFP on the it before I was able to do much of anything after I logged in on the Mac (my login items mount an AFP volume... it hoses things up enough that I couldn't bring up the settings utility to turn off the login item).
Hilarity.
Looking at the sourceforge code for netatalk, I don't see direct snprintf, but I'm guessing this may be some sort of a logging failure? That seems to be the main place that formatting is done?
Anyway, any help would be greatly appreciated.
[this repeats forever...]
Jul 21 19:25:02.889424 afpd[2811] {uams_dhx2_pam.c:321} (I:UAMS): DHX2 login: XXXX
Jul 21 19:25:04.094334 afpd[2811] {uams_dhx2_pam.c:210} (I:UAMS): PAM DHX2: PAM Success
Jul 21 19:25:04.109204 afpd[2811] {uams_dhx2_pam.c:653} (I:UAMS): DHX2: PAM Auth OK!
Jul 21 19:25:04.109544 afpd[2811] {auth.c:269} (N:AFPDaemon): AFP3.3 Login by XXXX
Jul 21 19:25:04.111969 afpd[2811] {auth.c:677} (N:AFPDaemon): afp_disconnect: trying primary reconnect
Jul 21 19:25:09.116178 afpd[2811] {auth.c:710} (E:AFPDaemon): afp_disconnect: primary reconnect failed
Jul 21 19:25:09.158863 afpd[2811] {volume.c:2129} (W:AFPDaemon): volume "USB_HDD_14" does not support Extended Attributes, using ea:ad instead
Jul 21 19:25:09.159925 afpd[2811] {volume.c:2036} (I:AFPDaemon): CNID server: localhost:4700
Jul 21 19:25:09.164454 afpd[2811] {fault.c:122} (S:Default): ===============================================================
Jul 21 19:25:09.164755 afpd[2811] {fault.c:123} (S:Default): INTERNAL ERROR: Signal 11 in pid 2811 (2-2-0-p5)
Jul 21 19:25:09.164975 afpd[2811] {fault.c:124} (S:Default): ===============================================================
Jul 21 19:25:09.165797 afpd[2811] {fault.c:96} (S:Default): BACKTRACE: 2 stack frames:
Jul 21 19:25:09.166098 afpd[2811] {fault.c:102} (S:Default): #0 /lib/libc.so.6(snprintf+0x1c) [0x201d0cd4]
Jul 21 19:25:09.166338 afpd[2811] {fault.c:102} (S:Default): #1 /usr/sbin/afpd(afp_options_parseline+0x166) [0x1c5d2]
Jul 21 19:25:09.168162 afpd[2168] {main.c:188} (I:AFPDaemon): child[2811]: killed by signal 6
Jul 21 19:25:09.271488 afpd[2835] {dsi_tcp.c:212} (I:DSI): AFP/TCP session from 192.168.123.112:49461
Jul 21 19:25:09.276759 afpd[2168] {server_ipc.c:231} (E:AFPDaemon): Reading IPC header failed (-1 of 14 bytes read): Resource temporarily unavailable
Hilarity.
- delhuxAspirantWhat is the best way to get this working under 4.1.6 on my NV+?
I tried kraney's suggestion, but it did not seem to change the behavior (though, I did get a couple of "No such file or directory" errors after running the chown command).
I'd rather stick with 4.1.6, as everything else is working right now... :)
