groperfish
Dec 19, 2012Aspirant
ReadyNAS Duo - blinking power button never ends
HI all, Have A ReadyNAS Duo with 2 x 750GB drives. I shutdown a few days ago (press and held power bitton until it blinked). The next day, upon startup, the power LED flashed repeatedly (No HD L...
emc
Jan 13, 2013Aspirant
I have same problem. I upgrade some packages thru apt-get command and after shutdown Duo v1 didn't get working. Only power led is blinking and ACT and HDD Lead no light. Can you tell me what Can I try first:
http://www.readynas.com/kb/faq/boot/how ... ash_device
http://www.readynas.com/kb/faq/boot/how ... _pc_or_mac
http://www.kossboss.com/rnasbootmenu
What is OS Reinstal? It will erase my data or just configuration etc? From my perspective the problem is with linux configuration or general soft problem failure. Should I try USB boot recovery or OS re-install.
I have 1,5TB disks so I dont have how to backup all data somewhere else. And last question it is possible to take one disk, connect to normal desktop and copy as usual data?
Plaese anybody can advice something?
