PeterD2
Jul 30, 2019Aspirant
ReadyNAS DUO - need to delete folder contents
Hi all, Got a fairly urgent and confusing problem with my ancient ReadyNAS Duo. I have an older Windows machine that created backups to the Duo (\\NAS\Backups\\Office4\). I don't need anything in ...
- Jul 30, 2019
You can reset the file permissions from the "advanced" tab for the share.
Just check the highlighted menu item, and click "apply" on the lower right. There will be a pop-up notification when it completes.
It that doesn't let you delete the folder from Windows, then you can alternatively enable http read/write access for the share, and then browse to https://nas-ip-address/backups You should be able to delete the folder from there. Note that the share name in https is case sensitive (unlike SMB).
Jul 30, 2019Guru - Experienced User
PeterD2
I actually checked both boxes, logged off and back on again from my Windows client and was able to delete the folders in question. Thanks kindly--this was a real bear to solve and I once again have room on my NAS!
- StephenBJul 30, 2019Guru - Experienced User
I'm glad I was able to help. :smileyhappy:
