mjvdhoek1972
Dec 07, 2017Tutor
ReadyNAS Duo / RAIDiator 4.1.16 [1.00a043]
Hi, My Netgear ReadyNAS is not working with Windows 10 - unless I enable the SMBv1 protocol in Windows10. My employer has disabled this option by default. Now internet is full of warnings that th...
- Dec 08, 2017
mjvdhoek1972 wrote:
Is it possible to enable SMBv2 and/or SMBv3 on my NAS ?? (and if so how ;-) ?)No., it only supports SMBv1
Netgear could release a firmware update I guess, but the project would be difficult because the underlying linux OS is so old. I don't think they will do that.
Dec 08, 2017Guru - Experienced User
mdgm-ntgr
Dec 08, 2017NETGEAR Employee Retired
If you can't enable SMBv1 or switch to another protocol e.g. NFS, then at this point it'd be time to get a new ReadyNAS. The Duo v1 was replaced in our lineup over 6 years ago now.
The RAID format on new units is different so you can't simply move the disks across.
