marakas
Mar 29, 2025Aspirant
ReadyNAS duo / RND2000 V2 disk mount and password reset
Hello Everybody, Thank you for all the participants in this forum, it helped me a lot. I relocated across continents, and after some years things settled back to "normal". After 5+ years I rea...
Sandshark
Mar 30, 2025Sensei
I know some things get blocked when the password remains the default, so making it blank may have similar restrictions.
FYI, the correct original solution was to do an OS re-install from the reset button menu, which resets the password to the default. At this point, I don't know if that would fix things or make them worse.
- marakasApr 06, 2025Aspirant
Sandshark wrote:FYI, the correct original solution was to do an OS re-install from the reset button menu, which resets the password to the default. At this point, I don't know if that would fix things or make them worse.
Thank you for the reply. Maybe I should have done a more thorough RTFM. I now have everything backed up, so I will try the proposed solution and see how it works. If not, I will just have to completely reset the NAS, which is probably the safest bet.
- marakasApr 08, 2025Aspirant
OK, so the OS reinstall did nothing wrt the passwords. I then did a complete factory reset, after which I found myself with no access to the web interface and no ssh connection possible.
I tried to install the apache2 updates from rdynsxtrs via serial console and 'n usb disk, but this failed citing "not a debian package" or similar errors.
the .bin packages cannot be installed from the command line?
So I will have to temporary bypass the https (the solution for the duo v1, will it work on the duo v2?) and then install the .bin packages through frontview.
But all in all it seems to be somewhat of a pain - I will look at installing debian and certain OMV packages.
