ross_fletcher
Aug 13, 2021Aspirant
ReadyNAS Duo & SMB 1.0
Hi. I have a ReadyNAS Duo V1 which I have used for backups but due to the SMB 1.0 situation will be replacing it shortly. I also have SONOS S1 which will also not read my music from my Windows 10 PC ...
Aug 13, 2021Guru - Experienced User
ross_fletcher wrote:
My question is, if I block them both from accessing the internet in my Netgear Orbi router, does this prevent my network from being susceptible to the vulnerabilities of SMB 1.0? Or is the presence of any SMB 1.0 enabled device on the network a threat full stop? Many thanks.
Opinions on this will vary, but in my opinion it is safe to run SMB 1 on a home network. The risks are much greater on a large corporate network. I still have it enabled on my main NAS, because I also have a media player that needs it.
The security issues with SMB 1 are due to the lack of authentication and encryption. The truth is while SMB 3 has both, they often aren't turned on anyway.
As far as internet access goes, your router is already blocking inbound SMB connections to your NAS, and it won't make unsolicited outbound SMB connections unless it is hacked in some other way. I don't recommend forwarding ports to the NAS - not because it's running SMB 1, but because it hasn't received any security patches in some years. But I don't think you need to do anything special in the Orbi to block its internet access.
ross_fletcher
Aug 14, 2021Aspirant
Many thanks for that. I just thought that since the ReadyNAS Duo does not require internet access then I might just as well block it.
- StephenBAug 14, 2021Guru - Experienced User
NTP (time sync) does use internet access. You can live without it, but the real time clock will drift (and if the coin battery in the NAS is dead, the clock will be very wrong when the system powers up). Clock drift depends on a lot of factors, but could be several seconds per day. So you'd need to manually check it, and adjust as needed.
The only other function that uses the internet is check for update, which is no longer relevant.
- ross_fletcherAug 14, 2021Aspirant
Thanks again StephenB.
